Re: Tomos A55 Lights Out
♣Slew Foot♣ /
The internal harness always gets frayed inside the fender. The flasher unit may have failed. Unless the lighting out terminal is molten on the regulator it is still good. The flasher unit is the same as a gm. There is a white wire that goes to the headlight. It always works loose losing ground to the lighting system.
