Check that your axle bearings are snug. You might need a wheel rebuild
As well, the bushings in the fork tubes go bad over time causing a little play. If that's the case you might need new forks.
Ride it by if you want a quick opinion
Subject | Written By | Posted |
Hobbit headset loose/wigglesTopic by: taylor Vogel | taylor Vogel | 03/21/19 02:55PM |
Re: Hobbit headset loose/wigglesRe: Ryan . | Ryan . | 03/21/19 02:57PM |
Re: Hobbit headset loose/wigglesRe: taylor Vogel | taylor Vogel | 03/22/19 02:18AM |
Re: Hobbit headset loose/wigglesRe: Totally normal JBOT | Totally normal JBOT | 03/24/19 02:54AM |
Re: Hobbit headset loose/wigglesRe: taylor Vogel | taylor Vogel | 03/24/19 03:20AM |
Re: Hobbit headset loose/wigglesRe: Totally normal JBOT | Totally normal JBOT | 03/24/19 12:05PM |
Re: Hobbit headset loose/wigglesRe: EH 📣FCC of the QCB | EH 📣FCC of the QCB | 03/24/19 09:02AM |
Re: Hobbit headset loose/wigglesRe: Barry (Bob) Brown | Barry (Bob) Brown | 03/24/19 09:37AM |
