No fuel flow into Honda Express Carb?
Dustin Schings /
I have this '80 Honda Express II and it is running out of fuel in the carb bowl. I noticed there was little fuel flowing through the hose from the petcock to the carb so I replaced the petcock real quick. Same issue though. When the fuel line is taken off the petcock, fuel flows freely from the tank. As soon as I put the fuel line on the petcock, the flow is stopped. The line is empty, but it will not even fill with fuel. Just a very SLOW trickle.
The carb is cleaned out, didn't even look too bad. I believe the needle that stops the fuel flow into the bowl needs adjusted based on this issue, but the tab on the float is plastic and can't be bent a little to adjust.
Is there something I can do to get this fuel flowing better into the carb?
  No fuel flow into Honda Express Carb?Topic by: Dustin Schings Dustin Schings 03/21/19 01:46PM
  Re: No fuel flow into Honda Express Carb?Re: P D P D 03/21/19 04:25PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/21/19 05:44PM
  Re: No fuel flow into Honda Express Carb?Re: Ryan . Ryan . 03/21/19 05:54PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/21/19 06:17PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/21/19 08:06PM
  Re: No fuel flow into Honda Express Carb?Re: Mike Kirn Mike Kirn 03/22/19 05:42AM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/23/19 05:20PM
  Re: No fuel flow into Honda Express Carb?Re: Kasey OKeefe Kasey OKeefe 04/04/19 04:09PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 04/06/19 11:49PM
  Re: No fuel flow into Honda Express Carb?Re: Jack Rutherford Jack Rutherford 04/11/19 12:12AM
  Re: No fuel flow into Honda Express Carb?Re: Ryan . Ryan . 03/21/19 08:19PM
  Re: No fuel flow into Honda Express Carb?Re: Mike Kirn Mike Kirn 03/21/19 09:48PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/21/19 10:15PM
  Re: No fuel flow into Honda Express Carb?Re: Ryan . Ryan . 03/21/19 10:20PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/21/19 10:58PM
  Re: No fuel flow into Honda Express Carb?Re: Ryan . Ryan . 03/21/19 11:19PM
  Re: No fuel flow into Honda Express Carb?Re: Dustin Schings Dustin Schings 03/22/19 12:20AM
  Re: No fuel flow into Honda Express Carb?Re: Mike Kirn Mike Kirn 04/04/19 05:57PM
  Re: No fuel flow into Honda Express Carb?Re: Stephen Keller Stephen Keller 04/11/19 01:11AM
  Re: No fuel flow into Honda Express Carb?Re: Jack Rutherford Jack Rutherford 04/12/19 12:09AM
  Re: No fuel flow into Honda Express Carb?Re: matt petrillo matt petrillo 05/04/19 10:28PM
  Re: No fuel flow into Honda Express Carb?Re: Stephen Keller Stephen Keller 05/04/19 11:37PM
