tomos bogs after braking
ben henderson /
Overall my tomos a55 is running well. But lately it has started to bog when I try to leave from a stop. Most noticable after a long stretch of WOT. If you just try to go WOT from a stop it bogs, can stall if you dont let up. Accelerate slowly and it will clear up and run fine again.
is this more likely a lack of fuel...or too much fuel?* Moved to this forum by simon
Re: tomos bogs after braking
Check for poor fuel flow. Bowl may be going dry and giving a lean bog. Also next time sit for a bit longer at the stop then try and see if it is better.
EH 📣FCC of the QCB /
Also with an A55 check the air box. They tend to load up with oil! You may have to take It think off and clean it with carburetor cleaner.
♣Slew Foot♣ /
Gas cap clogging.
OR if it's kitted the pilot jet needs adjusting. You might have a small airleak on the statorside or if it smokes on the trannyside.
Tri-ped Dave O.D.B. /
Also just try cleaning your carb since tiny dirt particles bounce around and lodge in the jet
