Re: Honda Hobbit - rebuild stator or buy economical CDI?
Jack Nielsen /
I HAVE VOLTAGE. I did like you suggested and there is voltage now coming off the black wire. My next logical question is why did blocking the points cause the voltage output?
My next step is to connect the black wire to the HT coil to see if there is spark. Should I return the points to their correct gap first or try it with the points in the normal position?
Another question is what should the output voltages be off each of the three wires,(black, red and yellow)?
Thanks for now. Jack
