Re: Motobecane Mobylette Repair
Totally normal JBOT /
Backfiring means your timing slipped. Set flywheel and points correctly and blast, and swap condenser at the same time.
If timing slips again lap the flywheel taper and crank with metal grinding compound to mate the surfaces together better
