Re: Base gasket. Dry or drippy install?
thanks for the info dudes!
Going to go with the old faithful and oil the gasket and try a little grease this tkme to hold it in place/ make removal easier.
I’ll leak down test the motor before mounting it to the bike to make sure and if it fails I’ll try building the deck wider in the thin area with jb weld as suggested.
