Re: A-3 no spark unless points are set less then spec.
Den 23 /
> Robert Timmons Wrote:
> As the title says I will have spark at a point gap of
> around .015-.025mm
This is .015-.025in. not millimeters. Set the points gap to .015in.
> but from what I’ve read the spec is .035-.045mm.
The correct metric equivalent is 0.35-0.63mm
>At first I was just finding TDC with a screwdriver
> in spark plug hole but since I wasn’t
> getting good results I bought a piston stop and
>did it that way. I’m assuming the rotor is 360mm?
I think you meant to write 360 degrees. If you're using a piston stop you will also need to attach a degree wheel to the rotor to find the EXACT top dead center.
If you use a dial indicator it's easier. Google " find tdc, piston stop, degree wheel " and watch some videos.
