Puch wiring- I’m a dummy
I took my bike apart without taking good pictures beforehand. My bad. I’m hoping one of you can point out the obvious before I get OCD and rewire the whole thing.
My stator doesn’t match any puch schematics I’ve found. From the stator I have:
BLUE
BLUE/BLACK
GREEN
BLUE/GREEN
YELLOW
The Blue, blue/black, and coil wire all got yanked from the terminal.
Attaching a before and after picture and hoping someone will tell me how dumb I am and how easy it is
Re: Puch wiring- I’m a dummy
EH 📣FCC of the QCB /
https://www.mopedarmy.com/wiki/Puch_wiring
Check out the wiki it may help. You should ground any “extra” wires your not using fromthe accessory coils.
If your not using all the switches I would look at the wiki how to wire for lights and clean up that wiring block and use some barrel connectors. (edited)
> connectors.
Been reading em
BUT
The main thing that’s throwing me off is the blue/green wire coming from the stator. Most diagrams have either a grey or a green/black or both.
You have a 5 wire vs the more common 6 wire which is better. Go to vintagemopeds.net and check out their diagram for the 5 wire. Not sure if this link will work:
https://vintagemopeds.files.wordpress.com/2013/01/1976-puch-maxi-5-wire-bosch-magneto.pdf
Look at baby Selby post a few down...
https://www.mopedarmy.com/forums/read.php?6,4222431
thanks so much. That's my stator so things just got a lot easier for me.
also didn't know that u were tittybats from @tittybats ! your stuff is dope, good luck with ur bike.
^^^ serously
Any luck?
I think I figured out where the crap I ripped out goes but haven’t had a chance to play with it yet.
At least I feel better about it now!
