Re: Setting up NU50 for premix
Captain Janeway /
Did you leave on the stock intake or switch? If stock, make sure to get the hose hookup at base of intake plugged. If you're not using that autochoke, sure remove it.
If the oil pump isn't in the way of something else, just leave it. I just ran the oil in and out hoses into each other and rolled the cables back up into the frame. pulled the reservoir.
