Re: Blind Bearing removal.
Bread winner!
I did this on a tomos trans cover once, was pretty difficult.
If the surrounding aluminum is thin, you'd better support the other side or you could blow right through it. And in that case, you may as well just heat the surrounding aluminum with a torch and slap it down onto a wooden benchtop, the bearing may just fall outta there.
