Blind Bearing removal.
Louis Brunskill /
Here's a trick.. my old time.. "young* friend taught me. I've heard of it.. just never used it. He says it's a dead ringer every time.. he's right!.. Pack bread in the dam thing... And hydraulically pump it out with a tight fitting pin and hammer.. too cool! Thanks: Alex Hedrick !
Re: Blind Bearing removal.
Alex Hedrick /
Hey man! Anytime!
Probably Fred /
If the side covers is thin cast aluminum or bearing is very stuck you’re better off getting a blind bearing puller
Andrew Squiggman /
Nice! Only cost you a piece of bread.
Totally normal JBOT /
Those bearings fall out with just a lil heat.
Bread winner!
I did this on a tomos trans cover once, was pretty difficult.
If the surrounding aluminum is thin, you'd better support the other side or you could blow right through it. And in that case, you may as well just heat the surrounding aluminum with a torch and slap it down onto a wooden benchtop, the bearing may just fall outta there.
kevin Smellaflange /
sometimes the right amount of heat is too dangerous
for the work area.
that AvE guy on youtube does it with little bits of greasey rags. works way better than those chinese slide hammer jawns...
good ol' uncle bumblefuck
Louis Brunskill /
I'll heat to reinstall... I just had to try the bread trick.. just to put it in my bag o tricks.. it was flat on the bench, and wasn't supper tight. No issues at all.
