Ever since I put the new engine kit on it won't idle unless the choke is on
I put a kit on my PA50 II and it won't idle with out the choke on is there a way to fix this if so how can I fix it?
Re: Ever since I put the new engine kit on it won't idle unless the choke is on
Fix your air leak at the base gasket.
Upjet
is the air filter there? being lazy i have found that u can unscrew those carb screws and blow air/carb cleaner to get the passeges freed up. run an inline fuel filter.
Tune the carb
golly gee whiz!
upjet/delete airleaks
...you can do this...
Easy Peasey. You just have to be patient.
(edited)
