Still sitting on my work bench in the garage, Still really cold here in Ohio. Also, I'm trying to figure out how to remove the small rear chain sprocket from the rear wheel. I have the thin 36mm wrench required to remove it. What I don't know is if the threads are reversed or not to remove it? from what I understand, That thing is on there tight from years of usage. Has anyone removed that rear chain Sprocket on the right side of the rear rim?
Re: Vespa Grande Rear trans rebuild instructions?
