Re: Variator weights answer...
Stephen Simmons /
> todd amundson Wrote:
> Ok so I did the long rally ride on Saturday. I thought id just limp half
> way if anything and break off early near my home but I stuck it out. I
> got the trophy for highest temps at 573 trail tech approved. The ride
> traverses mountains and rivers. Timings 1.8mm BTDC with a powerdynamo.
> Gearing is 21-35. Sure didn't feel hot and I didn't break down. Same
> results as a MVT Premium ignition that was on there before just hotter.
> Does idle better with the PD ignition. Same throttle response for the
> most part as a Mikuni TM24 that was on there before. My slides opening
> all the way as I checked it last night. I'm going to verify jetting in
> the PHBG today. Reeds are malossi yellow carbino. The pipe is a dirtbike
> thing. I would need to ditch it to try others and that's gonna be tough.
21/35 gearing on a flat reed? Also what thickness reeds? I used too heavy of a reed material in my flat reed and could only get 45. Swapped in a stock reed and hit 55. Bottom end was killer with the heavy reed but top end sucked.
  Variator weights answer...Topic by: todd amundson todd amundson 02/11/19 11:45AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/11/19 12:15PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/11/19 04:00PM
  Re: Variator weights answer...Re: Mike Boyd Mike Boyd 02/11/19 05:29PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/11/19 08:38PM
  Re: Variator weights answer...Re: Mike Boyd Mike Boyd 02/11/19 10:03PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/11/19 10:17PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/15/19 11:39AM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/15/19 01:40PM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/12/19 12:01PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/15/19 01:02PM
  Re: Variator weights answer...Re: Dirty30 Dillon Dirty30 Dillon 02/15/19 03:35PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/15/19 01:21PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/19/19 11:02AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/19/19 01:50PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/19/19 07:39PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/19/19 09:56PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/15/19 01:40PM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/15/19 02:54PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/16/19 09:27AM
  Re: Variator weights answer...Re: Ryan N. Ryan N. 02/19/19 12:18PM
  Re: Variator weights answer...Re: Dirty30 Dillon Dirty30 Dillon 02/19/19 10:42PM
  Re: Variator weights answer...Re: alex . alex . 02/20/19 01:51AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/20/19 03:54AM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/20/19 01:04PM
