Re: Variator weights answer...
Ryan N. /
I always start out with the lightest weights and then go progressively heavier. Once you start picking up speed, keep adding weight. Once you lose speed, lose weight and then you'll be in the sweet spot. Pretty simple. It could definitely be your exhaust too.
  Variator weights answer...Topic by: todd amundson todd amundson 02/11/19 11:45AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/11/19 12:15PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/11/19 04:00PM
  Re: Variator weights answer...Re: Mike Boyd Mike Boyd 02/11/19 05:29PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/11/19 08:38PM
  Re: Variator weights answer...Re: Mike Boyd Mike Boyd 02/11/19 10:03PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/11/19 10:17PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/15/19 11:39AM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/15/19 01:40PM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/12/19 12:01PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/15/19 01:02PM
  Re: Variator weights answer...Re: Dirty30 Dillon Dirty30 Dillon 02/15/19 03:35PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/15/19 01:21PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/19/19 11:02AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/19/19 01:50PM
  Re: Variator weights answer...Re: todd amundson todd amundson 02/19/19 07:39PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/19/19 09:56PM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/15/19 01:40PM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/15/19 02:54PM
  Re: Variator weights answer...Re: kevin Smellaflange kevin Smellaflange 02/16/19 09:27AM
  Re: Variator weights answer...Re: Ryan N. Ryan N. 02/19/19 12:18PM
  Re: Variator weights answer...Re: Dirty30 Dillon Dirty30 Dillon 02/19/19 10:42PM
  Re: Variator weights answer...Re: alex . alex . 02/20/19 01:51AM
  Re: Variator weights answer...Re: Stephen Simmons Stephen Simmons 02/20/19 03:54AM
  Re: Variator weights answer...Re: Totally normal JBOT Totally normal JBOT 02/20/19 01:04PM
