Re: Tomos Streetmate ignition coil mistery????
Lia the Raven /
The little metal strip is present on your flywheel then, I take it? If so, I think you've established either the pickup or its wires are bad by testing it against a good stator (verified by the 2 wire CDI) and two new 4-wire CDIs.
I suppose you might be able to test by hooking up a multimeter to it and moving the flywheel by hand, but I don't know what reading would be considered good or even what to be testing for.
