Re: Tomos Streetmate ignition coil mistery????
Lia the Raven /
If the 2 wire CDI works but 4 wired CDIs don't, assuming you have everything connected properly, then it sounds to me like either:
- someone swapped the streetmate's flywheel for an A35 flywheel - like an 01-02 Revival flywheel which would have starter teeth but possibly no metal strip for the pickup? I've never actually seen one.
or
- the pickup is bad
