Re: Vespa grande
Ike Pipe /
https://www.google.com/url?sa=t&source=web&rct=j&url=https://vintagemopeds.files.wordpress.com/2013/10/haynes-ciao-and-bravo-repair-manual.pdf&ved=2ahUKEwiL-r_UrK_gAhVEjoMKHcTZDM4QFjABegQIAhAB&usg=AOvVaw0DNlsesMIkU1p-qM3t80g4
That's what you want. It is for Ciao/Bravo, but the Grande drive train is nearly identical.
Yes, the chain is a bicycle chain.
For transmission fluid I use 80/90 high pressure gear oil. Get synthetic and it won't smell as bad.
There are basically two special tools you will want from treats: flywheel puller and there is a freewheel wrench. Both are worth the money.
