Re: Primary ignition coil
Daniel '' /
> Don M Wrote:
> 99.9% of  mopeds that don’t fire/get
> spark are not due to a faulty secondary HT coil (the one with the spark
> plug wire attached to it).  Also on that same note, electrical
> components usually break-down from either corrosion or heat or
> physical damage…in other words, usually, they don’t just break for no
> reason. The ignition parts that will most likely be the root of your
> inability to get a spark will either be in the contact points or the
> ignition switch/wiring.
Unless you have a Moby, then it's probably all bad
