Re: 1976 Puch Maxi Fuel Tank Cleaning with Evapo Rust.....
Jimmy Benedetto /
Did Final Flush Today, In the end Vinegar soak did the trick, Then tip upside down send gunk out of filling hole with Hot water from hose flushed till water tank wa empty, blow dry thoroughly and reinstall cleaned carbie and fresh gas with a taste of mystery oil zoom zoom runs like a champ......
I would not use Evapo Rust for this tank again a bit to heavy duty for this prodject....cheers
