Re: 1976 Puch Maxi Fuel Tank Cleaning with Evapo Rust.....
P D /
> Jimmy Benedetto Wrote:
> Thanks for that i was gonna use ball bearings,
> With same effect, been flushing for two days now still flushing out
> carb cloggin Dust and gunk.......grrrrrrrrr
You'll probably never get it all out .
Exactly why it's recommended to run an in line fuel filter good to at least 60 micron .
I use oxalic acid for rust . It does a very good job .
https://www.mopedarmy.com/forums/read.php?6,4160423,4160423#msg-4160423
If you want to rid yourself of rust in the tank , you should always keep the tank completely filled or line it with a good epoxy resin .
An excellent choice :
https://www.caswellplating.com/epoxy-gas-tank-sealer/caswell-epoxy-gas-tank-sealer-mini-kit-up-to-5-gal.html (edited)
