Re: Ciao crank bearings
Steve Davies /
So I've split engine again swapped the bearings over they did have the same numbers stamped on so assuming they was the same as each other but thought I'd swap them over anyway I also removed the oil seal during the fitting this time and put back in later.. it may have been the oil seal the bearings extra heating or just pure luck ! Either way the crank is now running nice and free so thanks to everyone who gave input ...
Cheers
