Re: Somethings leaking! Rings? Piston? Cylinder?
Caleb Walker /
Hey! Thanks Neil for the offer! Might take you up sometime but for now I'll keep truck'n.
So You asked fro it and here it is. the results of the compression test. at wot turning over with a drill, I'm getting about 125 psi of compression according to my gauge. its a cheap gauge, so you can take the measurements for what their worth. For comparison, i tested my 66cc engine and got right about 188 psi. both measurements make sense to me because the Peugeot cylinder is stock except for slight exhaust porting. the other engine has significant porting and head-work done on it.
