Re: Somethings leaking! Rings? Piston? Cylinder?
Neil Verchot /
Hey man I’m not too far from you if you wanted to swing by we can check it out. I’m not a big fan of compression testing because it doesn’t give you the full story. Leak down testing the engine is much more valuable information.
You could have a leaking decompression valve causing your issue.
Look into removing weights from the variator and adding a launch lever. You’ll have a blast with that set up
