Re: Crooked front tire
Adrian Salter /
Yup! Needs a spacer in here! Try about 5mm to start with. Make sure the lug for the brake hub is engaging far enough, but not quite bottoming-out.
It's not a permanent fix, but you could try packing out with washers to calculate spacer size.
Good luck. Adrian
