Re: 82 Towny wont rev,stuck in "start" mode !
Jack Rutherford /
I used the pw50 knock off stators and took the charge coil off of them. I found out that they are a direct fit but you had to flip the charge coil over and connect the ground as it was connected on the qt50 to the light coil for it to work properly on the qt50. I had one that worked for a little while and then fade because I didn't install it properly. same process on mj50
pw50 stator conversion (edited)
