Looking for a wiring diagram or some general info on the stock "electronic ignition" cdi on the spx models.
I've got spark and can run but no light power.
Haven't been able to find much just searching generally
If you're still in the shop around 6 I'll come by and galaxy brain it.
My friend and roommate also has one of these with the same problem, I'll have him chime in when he finds the answer.
so i've figured it out kind of, either there was a wiring change or someone really frigged with the wiring: all my yellow/green wires are hot power (according to some folk and repro units those are supposed to be ground) still trying to figure out what a single blue wire straight fro the stator is though
euro moped friends you're my only hope
Might want to employ your multimeter . ;)
> to
thats how i found my hot power, but ill probably swap to an aftermarket ignition anyway
Wait, did you ever figure out why you would ever buy a french bike yet?
EPIC BURN
I'd tell you, but you have to be over 18 to go onto the website.
