Re: Garelli rally sl please help
P D /
> Seth B Wrote:
> > pat splat Wrote:
> > lapp your flywheel to the taper, i use some rubbing compound and some
> > hand cleaner w pumice or u can just use lapping compound. just the
> > tight fit will hold the magneto in place.
> Can you explain this process to me, or point me to a thread on how to?
> I've heard a lot of lapping on here, but I'm not familiar with it.
> I feel I should be
Pretty simple :
Apply lapping compound to the taper . Then the flywheel goes on and gets hand turned a few in one direction , then the opposite direction as many times . Repeat until surfaces involved are showing smooth and matching . The idea is to create as much friction as possible between the crankshaft taper and the flywheel taper .
