Any suggestions Ignition Upgrade for 50cc four stroke Indian . ( same asHonda NC50)
CDI? anything reliable that will work. Thanks.
Not even remotely the same as the NC50.
I must have been misinformed. I do however need something that will work with my Indian 4 stroke. Thanks
PC50 is what you're thinking of.
but nah, I don't think theres any direct fits. never tried though, stock should be reparable.
they did share a few things in common with the cubs like c100 etc, might be lucky and find some parts overlap but no info on it - you'd have to gamble and get one to see if it works. The ignition coils I've seen are identical looking I know that much.
check out myrons for diagrams and tricks, he's got a quick schematic too to simplify ignition wiring and for testing, just scroll down to "I" for Indian
http://www.myronsmopeds.com/category/service/wiring-diagrams/
"The WTEMCO magneto is similar to a 90mm Bosch magneto, like on Puch mopeds. Many things interchange, like points, condenser, mounting plate. The original points are the older style 3-piece kind, identified by the e-clip. By removing the screw-in post, newer style one-piece Bosch points will replace the older 3-piece ones.The WTEMCO flywheel timing angle is close to Tomos, which is different than Puch."
