Re: 1980 Newport II
Mike Boyd /
Great bike! I love it when the pin striping on those Newports is still intact!
Carb rebuild kits are cheap and easy to do as you could probably tell after disassembly. You might be familiar with the larger Bing cousins if you ride a lot of BMWs too.
The stock cylinders are surprisingly resilient so you may only need to polish the bore and swap a new ring in, depending on what exactly is going on in there. The main thing is not to damage the crank, as that is more difficult to replace on those 2 speed engines. In fact I'd personally probably cut the damn cylinder off before risking too much stress on the crank with the wood/hammer method, since stock cylinders are basically free they're so common
  1980 Newport IITopic by: Robert Spine Robert Spine 01/13/19 06:24PM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/13/19 07:17PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/13/19 07:34PM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/14/19 10:13AM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/16/19 05:54PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/14/19 06:26PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 01/14/19 07:01PM
  Re: 1980 Newport IIRe: Chris * Chris * 01/14/19 07:59PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/19/19 09:32AM
  Re: 1980 Newport IIRe: P D P D 01/19/19 11:21AM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/30/19 06:46PM
  Re: 1980 Newport IIRe: Seth B Seth B 01/30/19 07:12PM
  Re: 1980 Newport IIRe: P D P D 01/30/19 10:26PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 01/31/19 11:45AM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/31/19 12:20PM
  Re: 1980 Newport IIRe: Don Ohio Don Ohio 01/30/19 10:58PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/31/19 04:00PM
  Re: 1980 Newport IIRe: Brad William Brad William 02/08/19 11:25PM
  Re: 1980 Newport IIRe: Brad William Brad William 02/08/19 11:42PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 04/01/19 05:44PM
  Re: 1980 Newport IIRe: Seth B Seth B 04/01/19 06:39PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 04/01/19 08:08PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 04/01/19 09:27PM
  Re: 1980 Newport IIRe: pat splat pat splat 04/01/19 08:56PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 04/01/19 10:29PM
  Re: 1980 Newport IIRe: Les B. Les B. 04/03/19 07:45PM
  Re: 1980 Newport IIRe: nash brunelle nash brunelle 04/06/19 01:26AM
