Re: 1980 Newport II
Robert Spine /
Here are a couple pictures of the moped. This bike has not even had the dust from 15 years of storage wiped off. The head came off easily, and the cylinder easily loosened from the case. The piston is obviously rusted badly inside the cylinder. I made a "yoke" out of Brazilian ironwood to place between the case and the cylinder and attempted to drive the piston out of the back of the cylinder. I attempted, it defeated me. 3 pound sledge hammer hitting a hardwood dowel did not move the piston at all. Tomorrow I try heat, but how much, to what specific parts and for how long? I have propane and MAPP. Do I gradually heat the cylinder or the piston skirt or both? How hot can I go without damage to the cylinder or does it even matter? I assume the cylinder is going to have to be replaced, along with the piston and rings. Just looking for some experienced guidance.
I pulled the carb, and completely disassembled it. I didn't take 'before' pictures of the insides, but I have seen worse. Everything was soaked in a carb dip for two hours and brushed off, run under clean water, and I used an air hose to blow open passages and dry things off. It will need a rebuild kit
More progress to follow, I hope!
  1980 Newport IITopic by: Robert Spine Robert Spine 01/13/19 06:24PM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/13/19 07:17PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/13/19 07:34PM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/14/19 10:13AM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/16/19 05:54PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/14/19 06:26PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 01/14/19 07:01PM
  Re: 1980 Newport IIRe: Chris * Chris * 01/14/19 07:59PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/19/19 09:32AM
  Re: 1980 Newport IIRe: P D P D 01/19/19 11:21AM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/30/19 06:46PM
  Re: 1980 Newport IIRe: Seth B Seth B 01/30/19 07:12PM
  Re: 1980 Newport IIRe: P D P D 01/30/19 10:26PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 01/31/19 11:45AM
  Re: 1980 Newport IIRe: Moped Lar (OFMC) Moped Lar (OFMC) 01/31/19 12:20PM
  Re: 1980 Newport IIRe: Don Ohio Don Ohio 01/30/19 10:58PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 01/31/19 04:00PM
  Re: 1980 Newport IIRe: Brad William Brad William 02/08/19 11:25PM
  Re: 1980 Newport IIRe: Brad William Brad William 02/08/19 11:42PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 04/01/19 05:44PM
  Re: 1980 Newport IIRe: Seth B Seth B 04/01/19 06:39PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 04/01/19 08:08PM
  Re: 1980 Newport IIRe: Robert Spine Robert Spine 04/01/19 09:27PM
  Re: 1980 Newport IIRe: pat splat pat splat 04/01/19 08:56PM
  Re: 1980 Newport IIRe: Mike Boyd Mike Boyd 04/01/19 10:29PM
  Re: 1980 Newport IIRe: Les B. Les B. 04/03/19 07:45PM
  Re: 1980 Newport IIRe: nash brunelle nash brunelle 04/06/19 01:26AM
