Like get rid of the pedal function completely? As in, completely remove the pedal shaft?
Hmmm I don't have an engine in front of me so i'm not sure how feasible that is....but since it's a completely separate shaft from the rear output shaft that tie in via a chain I suppose it would somehow be possible....not sure if it's worth it tbh. You'd be better off getting a flat reed as there is an easy kit treats sells to delete the pedal function.
