No problem, good luck with the rebuild.
Couple pointers:
- when re-assembling make sure that you have the little clip on the pedal selector in the right place. there is a spot in the case it fits that doesn't allow it to rotate much either direction.
- hard to describe but there is a little wishbone thing that move a gear on the pedal shaft. Don't remove said gear on pedal shaft. there are two small ball bearings with and a spring that will pop out. they are a real sombitch to get back in
