How to fix surface rust on chrome
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
Just bought a 50v and there’s a bit of surface rust on the handle bars. Could I just sand it out with a high grit? Kind of a newbie
Re: How to fix surface rust on chrome
You might try buffing it with a wad of aluminum foil and a bit of water or light oil .
> or light oil .
^^Do this. I've done the aluminum foil and water routine on several bikes. It works amazingly well. Like, better than a As Seen On TV ad.
0000 steel wool and rubbing compound works too.
0000 steel wool and wd-40 works as well.
Captain Janeway /
I just use foil and water. I think there's a section in the wiki on this.
