Internal ignition coils. Sachs 504
Xavier Wright /
So Ive had this what Sachs 504 engine. I was wondering how internal coils work. Finding a external motoplat is a pain but I see internal one for sell. If you have a wiring diagram for one that works I'd appreciate it.
Re: Internal ignition coils. Sachs 504
Dirty30 Dillon /
Any HT coil will function fine.
Xavier Wright /
What I trying to figure out is does it need to work with a primary coils and do I have to wire the point thru the condenser.
Are you talking about the internal coil that has the plug wire hooked to it? It so you remove your external coil off the frame and the ignition coil off the stator. You bolt the internal coil in the place if the ignition coil on the stator and wire it to the condenser.
Xavier Wright /
So it charges off of the flywheel, thanks. Can I wire it like a 3 wire moto off the condenser
You're talking about one of these right?
Xavier Wright /
Yeah. This is my plate that I have know. I'm not sure if a motoplat or Bosch matter
> Bosch matter
Looks hooked up right to me.
