Grimeca disc rim in ebr forks.
Recently I aquired a set of these wheels with the intentions of fitting the disc wheel onto my maxi in some EBR forks just wondering if anyone could chime In with any experience or thought?
It’s a proper grimeca off of a Tomos at50
I’m wondering how easily the disc will line upto the caliper on the ebr forks
Re: Grimeca disc rim in ebr forks.
Dirty30 Dillon /
You'll be hard-pressed to find any info on that particular setup from MA, only because the AT50/ATX50's were never sold or imported over here.
That said, I think with some proper spacing on both the caliper and rotor side, it should be workable fairly easily.
Tyler brekke has/had that set on his pinto. Pretty sure the same old tomos stuff will all work, 220mm streetmate rotor and ebr disc forks with the tomos caliper. It all should work together, but double check the measurements.
> the measurements.
Could I be a pain and ask for a link ?
I’m thinking to run a solid stainless steel disc give it a old look
I lied, its 180mm. You would have to make a little bracket for the caliper, probably no getting around that.
https://www.treatland.tv/tomos-mc50-grimeca-5-bolt-disc-rotor-180mm-p/tomos-oem-disc-rotor-243055.htm
I had a measure and I doubt that one will fit!
This is what I’m looking at putting on 218mm solid disc.
https://www.jmpbparts.com/remschijf-rvs-grimeca-velg.html
Ya that looks good. If they don't ship to the u.s. will janssen is cool about sending stuff your way.
I’m based in jolly old England
