Re: Is this bad??
Thomas Smith /
Replace your crank seals. Fix the insulation on the top coil with a little epoxy, it doesn't look bad so it's probably ok. The bottom coil is junk, so you'll want to find a new coil. The little one behind it is probably ok though. It looks like someone used something to try to hold the flywheel to get the nut off and wrecked the coil in the process.
