E50 shimming on stock clutch dmp crank
Running a dmp crank and a two shoe clutch with a mlm brace plate. On a pedal start bike
At hihi rpm my clutch bell seems to machine it’s way into my clutch cover.
The pressure plate rattles some too
Is this a shimming Issue with the dmp crank?
I have a box of e50 shims and I’m wanting to try a smaller rear shim behind the clutch bell and see if that makes a difference.
Re: E50 shimming on stock clutch dmp crank
What condition is your bushing in?
It looks decent no flats spots or obvious wear.
Will try another though
Be sure the clips and washers and shims are in their correct place....
