> Miguel Pagan Wrote:
> when the stock points ignition was replaced with the motobecane stock
> cdi you instantly lost your brake light circuit. what you need to do is
> get an inexpensive voltage resulator/ rectifier from treatland.tv for
> under 10 dollars. this particular one has one inlet from the cdi and the
> far two connectors are 12 volt outlets, one can be used for the
> headlight and parking light circuits and the other can be used for the
> brake light circuit. and when you do this, you will need to replace the
> handlebar brake switches for the ones with the black button also from
> treatland.tv. good luck and stay well.
^Miguel...which voltage reg are you referring to? I've been meaning to hook up my brakes for 2 years but haven't wanted to start hacking up the wiring to leech off the light circuit...if you could point out which regulator you're talking about I might actually regain my brakes (already have the different brake switches too!)
thx
