> Daniel '' Wrote:
> When you check the compression are holding it wot? 90 psi is low but I
> have had bikes run with less. Piston in upside down? Are you using the
> choke? Have you tried using a drill to start it?
The piston isn't in upside down. I made sure of that when I was putting the engine back together. I did multiple trials when i was doing the compression test including having it at wide open throttle and with the choke on. I've also tried all sorts for ways to get it going and did try it with a drill. It won't even start with starting fluid.
