Welding engine damage magneto?
Hi everyone I was going to weld a nut on to a Brocken stud to extract it (broken manifold bolt) . Just wanted to check, would welding cause any electrical damage to the magneto at all? I’ve removed the little ignition coil type thing from the top of the frame/engine. Any help is much appreciated, cheers Luke
Re: Welding engine damage magneto?
It never has to any of mine.
That’s great thanks
Unlikely to damage a magneto- they are just coils of copper wire around a laminated steel core.
However, be careful of all 'electronic' bits. Regulators, rectifiers, flasher relays etc. They can all be damaged by high voltage spikes that can occur when using a welder. Not sure what your particular moped might have, if in doubt, disconnect and remove it if possible.
Dirty30 Dillon /
Mount your welder's ground as close to the point as you can.
If you have a Katia which is kinda electronic heavy compared to early Garelli's, make sure the CDI/electronic bits are disconnected.
Thanks for the replies guys. It is a Katia. I have removed the engine so the only thing i’m Aware of is the magneto and all the points etc within it. I will try and remove as much as I can and follow the advice here
