Can anyone please help me? How do I remove the oil level sight for cleaning?
I have stripped all the paint but need to clean the area around the sight glass.
You cant remove it without destroying it or so I found. You can replace it with non-stock parts. If you want I'll post some pictures on how I did it.
Tape it off and sand/ clean around it.
How long till it leaks and the glass is clouded.
Mine is a 79 and still works perfectly.
> did it.
Are you waiting for an invitation ?
Post 'em . Along with a narrative , so no one gets the wrong idea . ;)
The best way to go about it is don't remove it at all...
Yes^^^
40 year old rubber seals dont stretch anymore without tearing or breaking.
> P D Wrote:
> replace
> > did it.
Give me a day to write it up. Can't sit for more then a minute or two at a time. My back is in bad shape today.
Someone else found and used a sight glass with gasket from a kobota tractor.
Thanks for the feedback!!!!
I know this is an old thread but just wanted to freshen a little for anyone searching for a solution to the NC50 oil level sight replacement. I bought a .79 inch fluid level sight window from J.W. Winco, inc. and will be putting it in my tank as soon as its painted. I will update the post with pics when I have them.
Please keep us updated
Jamie Namock, when I look up JW Winco sightglass it gives an option for .79 (diameter 1) or .79 (diameter 2). Do you recall which one you purchased?
