Hey there, I’m currently working on putting the L cover on my 1980 express. I have the manual and have been trying to piece it together, it’s seems to be a little confusing, I don’t understand why they explained things in the order they did. Anyways.
So I have followed the instructions and it works the way it should except the kick starter doesn’t return back up when I push it down. What I’m really confused about is should the return spring be engaged on the little cast piece BEFORE you your turn the kick starter to line up the notch on the sprocket with the lever.
