Speedo Cable brock off flush
So my speedo cable broke off flush in the speedo... Ive tried needle nose pliers and wd 40.. no luck.. any suggestions?
Re: Speedo Cable brock off flush
DrGeorgeTompson (Alan) /
More needley pliers
Remove speedo from mount to facilitate retrieval.
Try this: Clean the end of the stub the best you can using brake/carb cleaner and then super glue a small dowel (toothpick cut in half) to the stub. Then needle nose it.
