Re: Tomos A35 transmission issues
Buddy Shirey /
> Tomos Forever Wrote:
> There's a shim that goes in between the claw collar and the finale gear.
> The pillow side faces inward towards the sprocket. Check all your shims
> make sure they are installed correctly.
> check the clutch the cork shouldn't be touching the inside of the clutch
> drum you should have 1mm of space in between each shoe.
> Check the first gear clutch make sure its not binding againts the clutch
> drum.Pull on the drum back and forth should have very little play the
> manual has the correct specs.
I've checked all of this EXCEPT there is definitely not a shim between the claw collar and final gear.
That has to be my problem. I've never seen a shim like that before when taking one of these apart but this is also the first time I've rebuilt one and actually replaced the final drive gear bearing on the stator side case. I'm guessing this shim got lost during the rebuild. Fortunately I have I think 3 more sets of cases in my shed that have the final gear attached to them. I'll check those when I get home and see if I can't track down one of those shims.
Pat, I'm not sure about the weld splatter. If you're talking about the silver that's showing on the raised section around the peanut shaped opening in the case I think that's actually just wear from getting hit by the claw collar spring or something. Can't say for sure though. This engine came from a friend who got it from one of the dam riders years ago. It could have been welded at one point but not since I've owned it.
I'm seriously hoping it's that shim that tomos forever mentioned because my clutches are all new and nothing is binding in the bell. All my shims are present except for the one under the claw collar. All the bearings and seals on the clutch cover are new.
  Tomos A35 transmission issuesTopic by: Buddy Shirey Buddy Shirey 09/03/18 02:08PM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/03/18 05:02PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 05:13PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 06:47PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 07:50PM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/03/18 11:31PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/04/18 08:47AM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/04/18 08:13AM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/04/18 12:59PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/04/18 01:07PM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/04/18 11:00PM
  Re: Tomos A35 transmission issuesRe: fred sams fred sams 09/05/18 02:33PM
  Re: Tomos A35 transmission issuesRe: P D P D 09/05/18 04:08PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/05/18 07:31PM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/06/18 08:11AM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/06/18 06:53PM
  Re: Tomos A35 transmission issuesRe: Victor Black Victor Black 09/24/18 10:59AM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 04/06/19 12:52PM
  Re: Tomos A35 transmission issuesRe: Erica Shoffstottle Erica Shoffstottle 06/24/20 11:20AM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 04/06/19 07:05PM
