Re: Tomos A35 transmission issues
Tomos A35 /
There's a shim that goes in between the claw collar and the finale gear. The pillow side faces inward towards the sprocket. Check all your shims make sure they are installed correctly.
check the clutch the cork shouldn't be touching the inside of the clutch drum you should have 1mm of space in between each shoe.
Check the first gear clutch make sure its not binding againts the clutch drum.Pull on the drum back and forth should have very little play the manual has the correct specs. (edited)
  Tomos A35 transmission issuesTopic by: Buddy Shirey Buddy Shirey 09/03/18 02:08PM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/03/18 05:02PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 05:13PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 06:47PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/03/18 07:50PM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/03/18 11:31PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/04/18 08:47AM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/04/18 08:13AM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/04/18 12:59PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/04/18 01:07PM
  Re: Tomos A35 transmission issuesRe: Tomos A35 Tomos A35 09/04/18 11:00PM
  Re: Tomos A35 transmission issuesRe: fred sams fred sams 09/05/18 02:33PM
  Re: Tomos A35 transmission issuesRe: P D P D 09/05/18 04:08PM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/05/18 07:31PM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 09/06/18 08:11AM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 09/06/18 06:53PM
  Re: Tomos A35 transmission issuesRe: Victor Black Victor Black 09/24/18 10:59AM
  Re: Tomos A35 transmission issuesRe: Buddy Shirey Buddy Shirey 04/06/19 12:52PM
  Re: Tomos A35 transmission issuesRe: Erica Shoffstottle Erica Shoffstottle 06/24/20 11:20AM
  Re: Tomos A35 transmission issuesRe: pat splat pat splat 04/06/19 07:05PM
