QT50 voltage regulator
My second qt50 didn't have a voltage regulator on it when I go it. I took the one off my old one but there was no wire to hook up to it. I pulled apart the old wiring harness and traced the wire all the way back to where it was spliced together. Can I just cut the old one off and splice it with the other one? Is there a certain point it needs to be at?
Re: QT50 voltage regulator
Dirty30 Dillon /
WHY DID YOU START A NEW THREAD ABOUT THE SAME THING
it was general discussion if I put it there you would ask my why it's not on the repair thread...
Jack Rutherford /
if memory serves, you splice it into blue wire coming out of stator
ok thank you. going to try it today will that help with the headlight and tail light not working? I got a new spark plug and the blinkers are blinking now
