Sachs G3 1D - Bing 12mm Air Box
Hi all! First post, new here, just got my G3 yesterday.
I'm missing the back half of the air box on my Bing 12mm carb. Front half is there and functional, choke works fine. I'm trying to figure out how get an air filter on there so that it is functional and doesn't look awful. Can't seem to find many examples of people who have done that. Can anyone point me in the right direction? Thanks!
Re: Sachs G3 1D - Bing 12mm Air Box
post a wtb ad on buy/sell
awakeby java /
Thanks! I don't really want to buy anything yet, I'm looking for options on getting a filter onto my Bing 12mm carb. The front half of the air box works fine, but other than sticking a stock filter into that and figuring out a way to make it stay put, I don't know what else to do. Most of the bikes I've seen are running alternate carbs.
DrGeorgeTompson (Alan) /
It's the square bing right? Can't you just zip tie some foam over the end of the box?
awakeby java /
That's a great idea for the time being. I'd like to find something more solid in the future though. I've been thinking about making up a cad file for an adapter that takes the front of the airbox into a tube that will accept a standard clamp on filter. I can probably get that milled at our local makerspace.
Dr. Mantis Toboggan M.D. /
Treat's & Moped Junkyard both have reproductions of the original air box, filter and clip. Looks like Treat's is currently out of the air box though.
https://www.treatland.tv/category-s/98.htm?searching=Y&sort=5&cat=98&show=50&page=1&f-sachs=69
http://www.mopedjunkyard.com/sachs-air-box_c_525.html
awakeby java /
Yes, Can't help but feel like $35-40 is a bit salty for a plastic box though. If I end up running this carb I'll consider it. Thanks for your help!
> help!
So , take the difference from what you think is a fair price and compare that difference to what it would take to end up with an adapter to accept a clamp on ...
Your time , finding material and buying it . Then the cost of milling .
Maybe you live in China or possibly India .
Charles McCusker /
> help!
injection molded parts are expensive when you don't sell thousands of units. why you don't see much injection molded parts for these old mopeds (or old cars) you'll never get your money back out of the cost of making the mold. Either that or the part is being cast in urethane from a soft tool, again per piece price is high.
That said, personally I'd CAD up that adapter in probably 5 minutes, and have it 3D printed on HP's new printer out of nylon. part cost would be low enough that you'd be in it for less than that air box and including a mesh filter.
> your
> > help!
> a mesh filter.
That's great , if you happen to have access to a multi-jet fusion printer .
Can't imagine every garage has one . ;)
Charles McCusker /
> box
> > your
> > > help!
> of
> from
> and
> be
> including
> > a mesh filter.
> printer .
I mean I do have access to one, but that's not the point lol anyone can contact me and I can get you a quote, but alternatively, https://i.materialise.com/en and https://www.shapeways.com/ have them and are competitive on price. so if OP wants to print their 3D file, this isn't a bad option.
Charles McCusker /
all that said, i really wish i had a printer at home. i hate having to wait on work to print me parts, and while discounted, still having to pay for them.
awakeby java /
My CR-10 can theoretically print nylon, but that would be way more work than having shipways do it.
I'm just exploring options at this point.
Charles McCusker /
nice thing about the HP fusion jet printer is it does not build using layers, so you have a SOLID nylon part like you would with injection molding, so there is no directional weakness like you would have with layers.
Nylon panty hose secured with rubber bands zip ties or Velcro straps works OK.
Also hear rumor that the square ice tea plastic bottle is a good fit on the end if you want to mod something up.
The idea of 3D printing a back half that then effectively holds a quality aftermarket metal mesh filter would be the best option. I’m surprised there is not one made already out on treats as the stock air box is so restricting.
^what he said
pure leaf tea cost ya like a buck at most convenience stores and comes with tea... cut the neck part off, fits over the box pretty close, clamp it on (hose clamps, zip tie, glue whatever) and make some holes by the other end. You can get filter elements for lawnmowers at any autoparts and hardware stores and fit something in. don't want much, needs to be minimallt restrictive. could just silicone in a section of folder paper air filter from like a car even, but probably not worth it.
I don't use a filter on there anyway, but that'll do it.
