Re: question on updating upper yoke on old a3
Samuel Smith /
I take it you are looking for a new way to mount your current bars. The handle bars themselves are the same for the A3/a35 (I own both), and the only difference is how they are mounted. There may be a conversion kit that has a different bracket that goes on the top of your current forks, but you may be looking at new forks to do this. Idk.
I looked around on treats for you and you might just be looking at a new top plate for your triple tree. Maybe upper and lower triple tree? Idk. Look at the measurements it has and compare to what you’ve got on your ped. Good luck man. Get that rad look!
https://www.treatland.tv/original-OEM-tomos-A35-top-fork-triple-tree-blk-p/oem-tomos-upper-yoke-242005blk.htm
https://www.treatland.tv/tomos-OEM-early-a3-fork-UPPER-YOKE-SILVER-p/tomos-oem-upper-yoke-214828sil.htm
